Just wanted to tell about a project I just finished. I Installed a Edis 4, an wasted spark FORD enhanced DIS ignition system without cam sensor. The Edis system runs straight off a trigger wheel mounted on my crank pulley along with a VR sensor. Which throws away my distributor completely. It has the ability to program accurate ignition curves, shift lights, all kinds of other useful features through Megajolt which is about like Megasquirt without fuel.
The idle is smooth as ever and power is great. Timing is dead on. The project has enhanced all the mods ive done to this g63b 2.0 and I dont think ill ever be done tuning.
I will post pictures later tonight.
Does anyone know the stock advance curve for a 2.0 Nippondenso distributor or mechanical degrees?
