What did you do to your truck today?
Forum rules
Re: What did you do to your truck today?
Postby LethalEthan » Wed Sep 09, 2009 8:05 pm
That VHT Flame proof paint holds up pretty well on the turbo manifold on the 240. Last time we checked the temp of the manifold after a short run was around 600 degrees.
LethalEthan
Engine Size: 2.3L
Postby Johnboy72 » Thu Sep 10, 2009 3:31 am
Well I assumed that valve cover would see some heat. So that's why I went that route.
Johnboy72
Postby LethalEthan » Thu Sep 10, 2009 3:36 am
I think it was actually sam that told me regular ole spray paint is good for up to 500 degree's could be wrong though.
LethalEthan
Engine Size: 2.3L
Postby BOOSTED88D50 » Thu Sep 10, 2009 11:05 pm
Made it look like this...
2.6 Soon to be megasquirted and turbooooooooed.
BOOSTED88D50
Engine Size: 2.6
Postby 4doorciv » Fri Sep 11, 2009 12:55 pm
Yesterday, changed the biss(I think it means base idle set screw) screw o-ring cause it was leaking. Also found my tb shaft seal leaking to and attempted to change it. Right now I'm sitting with a truck without a throttlebody. Took out the tps sensor, took out the 12mm nut holding the arm. Arm won't come off and stripped the 2 screws holding the throttle plate to the shaft.
-Ryan-
4doorciv
Engine Size: 4g63
Postby MightyG54BTMax » Sun Sep 13, 2009 5:51 pm
Took out the junk rad and put in the one from my Starion along with the electric fans and entire part of the harness. Took out all the wire nuts from previous owner and solder all connections. Made custom stereo brackets out of my Starion stereo brackets so the cd player doesnt skip with every bump. Started routing the Megasquirt wire harness.
MightyG54BTMax
Engine Size: 2.6
Postby LethalEthan » Sun Sep 13, 2009 5:55 pm
New foglights hooked up. Hope to have some HID's in them soon. with my headlights and fogs both having HID's the front of my truck should look something like the sun hahaha. New ignition with 2 step rev limiter might be coming soon as well.
LethalEthan
Engine Size: 2.3L
Postby Spicoli » Tue Sep 15, 2009 6:55 pm
Walt with your big diesel, Id look for a 1st gen montero tranny to pull and swap in that hydro clutch would be nice w/ your diesel i beleive
--keRby
Ad Inexplorata
Spicoli
Postby Johnboy72 » Thu Sep 17, 2009 5:54 pm
I walked past mine today, that's sad!!!
Johnboy72
Postby Spicoli » Thu Sep 17, 2009 6:53 pm
Started to put in 3in blocks, u bolt stripped, cheeap ass POS china made ubolt
--keRby
Ad Inexplorata
Spicoli
PreviousNext
Return to General Talk
Users browsing this forum: No registered users and 4 guests
