mightyram50.net • View topic - weber 32/36 question
Postby TotallyBalistic » Mon Sep 14, 2009 3:53 pm
here we go with the question that could be answered with alittle research. id just rather hear it from somebody on here for some reason. so what i was wondering, on my weber 32/36 it has that adjustment screw at the bottom that i assume is the fuel/air mixture screw, what dirrection does what when you turn it, tighten it shuts off fuel or what? i dont wanna hear all that look it up crap i just need and answer
595
TotallyBalistic
Good Times
Good Times
Engine Size: 2.0
Re: weber 32/36 question
Postby Aeroheadcww » Mon Sep 14, 2009 6:24 pm
That is the idle mixture screw, it controls the air/fuel ratio for closed throttle only. Screw it in leans the idle, screw it out enriches it. Rule of thumb I've always used is adjust it until it gives the fastest idle speed. After that you can adjust your idle stop screw to the desired idle speed, then maybe tweak the mixture a little again.
Good luck tuning! :)
Aeroheadcww
Engine Size: 2.6
Postby TotallyBalistic » Mon Sep 14, 2009 8:46 pm
thanks man that was pretty helpful, after the rain clears out ill get ontop of that. many thanks
595
TotallyBalistic
Good Times
Good Times
Engine Size: 2.0
