Msd ignition
Msd ignition
Postby austin » Fri Dec 04, 2009 9:35 pm
Has anyone had any experience with using any msd ign on our truck? I have an msd offroad that I got about 6 years ago, but never put it on the truck it was bought for. I just want to know if it is worth messing with.
Guns kill people like forks kill people.
austin
Engine Size: 2.0
Re: Msd ignition
Postby pennyman1 » Sun Dec 06, 2009 6:17 pm
I ran an MSD 5 Ignition on my 80 d-50 for years with the original blaster coil- didn't really notice much of a difference with it. I got better performance with Nology wires and NGK platinum plugs gapped to .055. Can't run an MSD with the Nology wires.
pennyman1
Re: Msd ignition
Postby austin » Sun Dec 06, 2009 9:55 pm
I would have thought that it would have made a difference. How many times does a msd ign spark? I may put it on anyways though.
austin
Engine Size: 2.0
Re: Msd ignition
Postby pennyman1 » Thu Dec 10, 2009 3:43 pm
10 times a cyl up to 3000 rpm, then a longer single spark. It may have been I didn't notice because it was put on with other items at the same time; it surely can't hurt.
pennyman1
Re: Msd ignition
Postby 79D50 » Wed Dec 16, 2009 8:03 am
It absolutely improves response, MPG, and overall power. If you are sitting on a stock motor then you will not see a huge improvement. If you are a sitting on a modified motor with a bigger carb (more fuel) and head/exhaust work than it makes all the difference in the world. The spark on the EI is weak. If modified you need a stronger spark to get a clean efficient burn meaning your not blowing fuel out of your tailpipe. You get much better throttle response out of this system. I have yet to fire my new motor but have had the MSD system on previous vehicles with excellent results and reliability. Install it, set it, adjust your timing and forget it forever.
The full system (new) will cost you approximately $600 bucks
1. MSD 6AL box
2. MSD Blaster 2 Coil
3. MSD 8.5 mm Wires
4. Only run NGK Plugs
79D50
Donator
Donator
Re: Msd ignition
Postby fixerupper10 » Tue Mar 30, 2010 5:10 am
actually i did the price stuff for all that cuz all that i didnt think would be that much. its only like $400 relatively affordable for anyone wanting to put this in the truck.
fixerupper10
Engine Size: 2.6
Return to Ignition Upgrades.
Users browsing this forum: No registered users and 4 guests
