by pennyman1 » Thu Dec 17, 2009 7:21 pm
			Will 1st gen s-10 shocks fit? They fit the d-50s and most other mini trucks- if they do , then you got a wide choice. Or get the Tokico trailmaster shocks- they have a bumper inside the shock to prevent damage if you bottom out.  If the shocks bolt across the lower control arm hole, use longer bolts and spacers to place the lower end of the shock lower, increasing the travel length and preventing the shock from bottoming out.
