Is there a way a way to calibrate the speedometer in a 2nd gen MM?
after installing my new gauge setup my speedo appears to be about 10 mph off. needle placement looks correct, so i am assuming that would only account for 2-3 mph tops.
when I was swapping the speedo element between clusters I noticed a small lever type mechanism attached to the spring for the speedo gauge. Is this an adjustment of some sort? It seemed a little loose while I had access to it so I can't imagine it would be able to keep a setting if that actually is it. Is the looseness in it a self adjustment of some sort that maybe it will just center itself over time?
Any help is appreciated.
Btw, that looseness I described is guaranteed to be the way it is supposed to be because both clusters seemed to have the same tension on that part.
