mightyram50.net • View topic - Help me understand this
Suspension Drops, Air Bagging, and all Ground Slamming Modifications.
Postby netstat » Sun Jan 31, 2010 10:40 pm
Either I am retarded, or just dont understand everything i need to yet.
someone explain why this is necessary
http://www.minitruckinweb.com/tech/chas ... rails.html
netstat
Engine Size: 2.4L
Re: Help me understand this
Postby MightyG54BTMax » Mon Feb 01, 2010 3:30 am
which part of it? narrowing the frame or Z''ing it?
MightyG54BTMax
Engine Size: 2.6
Postby netstat » Mon Feb 01, 2010 3:42 am
pretty much if its in that article i dont get why.
i understand the "part 2" article on modifying the lower ball joints and spring mounts ... but i'm lost on the one i posted.
netstat
Engine Size: 2.4L
Postby netstat » Mon Feb 01, 2010 12:34 pm
nevermind ... i get why they needed to do all that for clearance now ... they were trying to tuck 20's on that one ... since I don't plan on going with huge rims I don't think I'll have to bother with all that.
Would still like to know about it tho if someone is board enough to fill me in. (i have a feeling that its alot of typing)
netstat
Engine Size: 2.4L
Postby MightyG54BTMax » Mon Feb 01, 2010 2:04 pm
Z'ing the frame helps to lay the frame out instead of dragging the front xmember. And I'm guessing they narrowed the frame to tuck rims with an offset that wouldnt tuck.
MightyG54BTMax
Engine Size: 2.6
Postby Spicoli » Mon Feb 01, 2010 4:45 pm
Z'n just stops the x member from dragging. Narrowing just helps tuck tires.
--keRby
Ad Inexplorata
Spicoli
Postby pennyman1 » Thu Feb 04, 2010 6:23 pm
Mitsus also have a frame that sits higher in the front than the rear when lowered. Z'ing the frame fixes the issue by correcting the rake and raising the x member like others stated
pennyman1
Postby netstat » Thu Feb 04, 2010 7:52 pm
pennyman1 wrote:Mitsus also have a frame that sits higher in the front than the rear when lowered. Z'ing the frame fixes the issue by correcting the rake and raising the x member like others stated
why would you do that instead of drop spindles tho? same result minus getting the cross member further off the ground right?
netstat
Engine Size: 2.4L
Postby MightyG54BTMax » Fri Feb 05, 2010 5:41 am
they do it so the frame lays flat. If you dont Z the front of the frame is up off the ground while the back is on the ground.
MightyG54BTMax
Engine Size: 2.6
Postby netstat » Fri Feb 05, 2010 7:08 am
damn. I knew I was going to have to modify the frame for my planned bag setup ... I REALLY didn't want to get into cutting the front up tho. :(
I lose.
netstat
Engine Size: 2.4L
Return to Suspension / Lowering
