dragginmits wrote:the motor is a 68 block punched .060 over i know its alot but its not going to be driven alot so temp should not be an issue flat top pistons cammed with 504 lift And 1.6 roller rocker GT40 heads (cobra heads not "p" heads) msd ignition probillett distributor and blaster coil edlebrock performer intake (will be replaced with a torqer II in april if it will fit) holly 600 cfm carb electric choke vacume secondareis. with ford 9 inch 3.50 gears and a c-4 trans and a tci 2400 stall torque converter behind it
