mightyram50.net • View topic - What did you do to your truck today?
Forum rules
Re: What did you do to your truck today?
Postby TotallyBalistic » Fri Mar 19, 2010 9:37 pm
yall are making me sick...i wanna work on my macro so bad
595
TotallyBalistic
Good Times
Good Times
Engine Size: 2.0
Postby MightyG54BTMax » Sat Mar 20, 2010 11:43 am
got the driver side c notch in. hopefully I can get the passenger side in tonite or tomorrow.
MightyG54BTMax
Engine Size: 2.6
Postby TurboMax » Mon Mar 22, 2010 6:53 pm
Replaced my brake master cylinder. Got a great deal from autozone on a new brake master cylinder. Only $42 and I don't need to return a core. :) It included everything including a new reservoir and cap plus a bench bleeding kit.
TurboMax
Engine Size: 2.6T
Postby Ramit » Fri Mar 26, 2010 3:56 pm
Installed a new secondary diaphragm on the Mikuni carb.Had to replace the used one that Natureboy sent me about a year ago.Also put in a new air filter.Along with everything else i have replaced in the last 2 months,this is the best that this little truck has ever run since I got it about 16 months ago.I didn't realize just how strong these little 2.0's could be!
If you love something, set it free. If it comes back to you it's yours to keep.If it doesn't come back, hunt it down..and kill it
Ramit
Donator
Donator
Postby Spicoli » Fri Mar 26, 2010 5:35 pm
TurboMax wrote:Replaced my brake master cylinder. Got a great deal from autozone on a new brake master cylinder. Only $42 and I don't need to return a core. :) It included everything including a new reservoir and cap plus a bench bleeding kit.
Someone needs to come up with an idea for a big master cylinder swap, if I had a spare V6 one Id see if it bolted up. Maybe I could do some measuring and looking see if its plausible.
Any one know the bore on the MC?
--keRby
Ad Inexplorata
Spicoli
Postby TotallyBalistic » Fri Mar 26, 2010 5:47 pm
i used the master cylinder and booster for a 85 chevy 1 ton on my 4x4...had to modify the fenderwell a bit but i got a big master and booster now that gives me enough braking power to stop that truck dead in its tracks with 38's
595
TotallyBalistic
Good Times
Good Times
Engine Size: 2.0
Postby TurboMax » Sat Mar 27, 2010 5:05 am
Spicoli wrote:Any one know the bore on the MC?
15/16"
TurboMax
Engine Size: 2.6T
Postby MightyG54BTMax » Sun Mar 28, 2010 11:28 am
Made my cross memeber for my 4 link, but its a little chilly for me out there today to put it in. Hopefully sometime this week it will go in.
MightyG54BTMax
Engine Size: 2.6
Postby zipperd50 » Thu Apr 01, 2010 8:24 pm
painted the stock wheels gold and the wiper arms and got better used tires that all 4 are now matching and have the same tread..1st thing so far done to it after putting 4 speakers and a 10" sub and amp
zipperd50
Engine Size: 2.6L
Postby pennyman1 » Sat Apr 03, 2010 6:18 pm
Found the short in the electrical system and turned the truck around in the garage to finish wiring up the new electric fan controller.
pennyman1
PreviousNext
Return to General Talk
