mightyram50.net • View topic - holly carb swap?
holly carb swap?
holly carb swap?
Postby zipperd50 » Mon Mar 29, 2010 6:17 pm
i was wondering if you could use a holly carb from a 89 2.0L MM for a 89 2.6 D50? both being 2wd
zipperd50
Engine Size: 2.6L
Re: holly carb swap?
Postby pennyman1 » Mon Mar 29, 2010 6:25 pm
Yes they are interchangeable, but you may want to rejet for best performance
pennyman1
Postby zipperd50 » Mon Mar 29, 2010 6:31 pm
could i take the jets from the stock carb?
zipperd50
Engine Size: 2.6L
Postby pennyman1 » Wed Mar 31, 2010 9:15 am
The stock carb is a mikuni, so I doubt they'll fit.
pennyman1
Postby zipperd50 » Sat Apr 03, 2010 5:57 pm
theres a lot of vaccum lines on the stock carb..am i going to have to hook them up to the new carb or do something different?
zipperd50
Engine Size: 2.6L
Postby pennyman1 » Sat Apr 03, 2010 6:13 pm
Most of the lines go to the box on the left inner fender for the old carb; they won't be needed anymore. The ones you need are the one from the throttle plate to the vacuum advance on the distributor and the big one over to the brake booster. You can also leave the one to the evap canister for the fuel tank and run the big line to the air cleaner for vapor from the gas tank. If your's is a smog inspection state, you can stealthly hook all the rest of the lines up so they look right, but really go around in a big circle.
pennyman1
