mightyram50.net • View topic - New From Southern Cali.
A place to introduce yourself and get aquainted with the other members.
Come on in, we don't bite!
Forum rules
Postby 2.0 wonder » Sat May 29, 2010 12:13 pm
Hi guys, found the site when looking up referencing how-to's on 4G63T swaps from another site. Currently own an 88 Mightymax Base model with an Automatic, deciding to whether to keep the wideblock auto combo or build up or use th narrowblock configuration with the 5speed I snagged out of a donor truck. Looking forward to being active to the Site!
2.0 wonder
Engine Size: 2.0
Re: New From Southern Cali.
Postby DroppedMitsu » Sat May 29, 2010 1:58 pm
Welcome, any questions you have just ask. I have swapped a 4g63t in my truck, so I can help out a little with whatever you need help on.
-Josh-
1989 Macrocab Mighty Max
DroppedMitsu
Engine Size: 4g63
Postby 2.0 wonder » Sat May 29, 2010 9:27 pm
Thanks, when the time comes I'll keep that in mind.
2.0 wonder
Engine Size: 2.0
Return to Newbies
