wrngwae wrote:it should work the autos have a separate ecu for the trans. and 2wd vs 4wd shouldnt matter either.
Spicoli wrote:the 4x4s use a different lil mini ECU that controls the 4x4 light and some other things its the black relay under the kick panel youll see it when you get ready to pull the ECU.
BTW KX you gonna have that thing running by August? I otta have something mitsu ready to run by then.
niftyd50881 wrote:i thought the common reason they go on 2.0 and 2.4 FI is the leaking capacitor issue.
and your oil buring could be just worn valve stem seals. although if the rings are bad...
have you pulled it apart and checked, these are somewhat easily repairable issues if you have the time.
