by 83L200 » Tue Nov 10, 2009 6:42 pm
i started fitting the heater back into the ute, becouse i had to move the fire wall the heater dosnt fit in the factory place, i had to cut up the heater casing and plastic weld it back together so it would fit under the dash, and becouse the back of the motor sits against the fire wall its a pain in the arse getting my hands in there to get to the heater pipes, it will be all worth it when its done though.
83L200 on Wed Nov 11, 2009 5:05 pm, edited 1 time in total.
