What did you do to your truck today?
Forum rules
Re: What did you do to your truck today?
Postby shultz » Tue Nov 10, 2009 4:51 pm
Well after 3 carburetors and 2 1/2 months I finally threw in the towel and took it to a mechanic close to my house who has been doing it for 30 plus years. He found that the enrichment solenoid valve not working correctly, could not find another so he shimmed this one???? but anywho it's fixed and now I'm a happy camper
There only original once
shultz
Engine Size: 2.0L
Postby 83L200 » Tue Nov 10, 2009 6:42 pm
i started fitting the heater back into the ute, becouse i had to move the fire wall the heater dosnt fit in the factory place, i had to cut up the heater casing and plastic weld it back together so it would fit under the dash, and becouse the back of the motor sits against the fire wall its a pain in the arse getting my hands in there to get to the heater pipes, it will be all worth it when its done though.
83L200
Engine Size: 4G63
Postby MMaxx94 » Wed Nov 11, 2009 9:51 am
this past weekend:
trailered truck to new home, broke into it.. couldn't get anything electrical with solenoids to work.. and battery was not dead
stupid relays...
yesterday:
replaced my emergency switches for my shaved doors... can now get into it without a clothes hanger.. haha
this afternoon:
removing bed and touching up paint... will soon tunnel out for driveshaft and relocate gas tank =)
94 Max
<Under ConsTrucKtion>
00 Dakota 4X4
V8 Magnum Mud toy =)
04 Mustang [DD]
true dual exhaust, rims, custom audio & interior, lowering springs
http://www.myspace.com/XoStangBabyXo [add mee]
MMaxx94
Postby laidout » Mon Nov 16, 2009 7:34 pm
well got the head back to find out it had a cracked head and the spare head was crack too ugg :cry:
laidout
Engine Size: 2.6
Postby Mighty6 » Sat Nov 21, 2009 5:09 pm
I changed my tire today as it shreded going 75 down the highway! WOO
Mighty6
Engine Size: 6G72
What year vehicle do you own?: 1994
Postby JRSJ » Sat Nov 21, 2009 8:47 pm
Took apart the door panel to see how much room I have for the stereo setup I'm planning -- not a lot. Need to rethink how to do it. Also going to do an oil change this week, and get my freshly welded tow bumper back on for the winter. Canopy is prepped for paint, but I might just buy a another one with a locking back window. Oh well. :)
Also have a person interested in my 91 Daytona. Would be nice to get rid of this:
JRSJ
Engine Size: 2.0
Postby Johnboy72 » Sun Nov 22, 2009 6:23 pm
Hid a present for the wife in the bed then put a couple of spare fenders over top of it. Then used my truck as a saw horse to cut some 2x4's. Let Primer in the garage cause its getting colder where I can leave door shut...so he sat in the truck and chilled thinking he was gonna go for a ride. Been thinking about motor mounts though.
Johnboy72
Postby prospect » Sun Nov 22, 2009 6:57 pm
tore my steering column apart....multi-switch looks fine but my dims arent working.
changed my headlight cups and wipers, then topped off my tranny and diff.
prospect
Engine Size: 2.6
Postby shultz » Sat Nov 28, 2009 6:58 am
Got 4 new skins this morning on my 86 Ram 50-Discount Tire. P195/75R-14 Kumho Solus KR21. Mount/Balance/valve stems/tire disposal/lifetime rotations and balancing. Total price of $223.36 + tax. My other tires were square and dry rotted. Rides like a new one now.
shultz
Engine Size: 2.0L
Postby TurboMax » Thu Dec 03, 2009 4:30 pm
Prep the truck for winter driving. OIl and filter change. Replaced the tranny fluid and trans. pan gasket since it was leaking. I'm going to skip putting the aluminum cap on for the winter. I just got to find something to put in the bed for added weight when it snows.
TurboMax
Engine Size: 2.6T
PreviousNext
Return to General Talk
